diy speakers that sound bright like klipcsh
Discussion in 'Archived Threads 2001-2004' started by MichaelDW, Jun 28, 2002.
  1. MichaelDW
    MichaelDW Stunt Coordinator
    Dec 2, 2001
    60
    wich speakers do you use, to get the high crisp sound like klipsch? I just purchased a psb center speaker and can't tell if I like it yet. I listen to klipcsh at the store and they had a cleaner sond to me, the problem is I built this entertainment center to fit the psbc6i dumb, dumb, dumb,.
  2. Mike Strassburg
    Mike Strassburg Second Unit
    Nov 4, 2001
    421
    I was in your exact predicament about 6 months ago. Solution: I bought a bunch of Klipsch speakers!!
    If you really like the Klipsch sound then I say buy some instead of taking a chance on a DIY, unless you can hear them first to be sure it's the sound you want.
    Good luck...Mike
