DIY Salamander rack w/ extrude aluminum (1 Viewer)
cacu
Inspired by the rack that Bret Miles did. thread
I'd like to build one. Does any one have a detail Bill of Material (BOM) to build one. I'm getting ready to order but don't know what nuts and bolts I need.
Also a more detail picture or instructions would be nice.
Allen Ross
edit, ohh thought you meant a flexy rack, try searching metal supply stores and asking about that extruded aluminum, as once you find that they will know what hardware to mount the shelves with.
cacu
Got my 80/20 extrude aluminum cheap on ebay: here
I got the #1020 1"x2" $13.50 for 56". Cheaper then I can get the 5/8 threaded rod for the flexy rack. I also got the T-nuts from them. Works out great.
I was going to do the flexy but found out that I can do the extrude aluminum for cheaper.;)
TheThrillisgone
