diy s-Video cable? What is the best way?
Discussion in 'Archived Threads 2001-2004' started by Jason Monette, Apr 2, 2001.
  1. Jason Monette
    Jason Monette Second Unit
    Aug 16, 2000
    266
    The subject says it all, what is the best DIY s-video cable? And how do you construct it?
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    The answer is don't even bother to try it. S-VHS connectors have very, very small internal connections, and these are best soldered by a pro or even better a robot.
    If you need a custom cable length have http://www.markertek.com make it for you
  3. Sundar Prasad
    Sundar Prasad Stunt Coordinator
    Jul 26, 2000
    54
    I made one using 2 separate 75-ohm Mogami cables (one for Y and one for C) and Ultralink connectors. Works beautifully. I soldered the connections without a hitch. The Mogami's were 22 ga. if I remember correctly, and the Ultralink's diameter on the back end was just right to let both the cables through.
  4. Richard Driskill
    Richard Driskill Stunt Coordinator
    Apr 1, 2001
    55
    Jason,
    It's not hard in my opinion. I've done it many times. All the items are available at your local Radio Shack. Just use a small tipped iron, fine soldering line and don't forget the proper flux.
