Mike<>P
Grip
- May 9, 2004
Hello everyone here are a few pics of my new sub box. It is a dual 15" Titanic ported design built according to the specs on the PE website with a few port deviations(port#'s and dimensions)OK'd by the tech line using the same program(BassBox6 Pro). I also used winISD and came up with similar specs.
How does it sound? Well....I can't really say for sure but as long as you're not in the same room as the sub, it cranks!..........I have serious cancellation issues(posted in the HT/interior forum)
It isn't painted because it will be built into the wall and hidden by a grill. Hiding it was pretty much the only option as it is HUGE! (21"h 45"w 26"d)
BTW: picture it with the top installed! sorry
