Chris Tsutsui
- Feb 1, 2002
I want to make a cable that goes to my sound card on my PC, to the inputs on a parasound 2 channel amp.
http://www.bus.ucf.edu/cwhite/theater/DIYCable.htm
First I saw this site and then I found the interconnects to use at this site: http://www.markertek.com/MTStore/pro...aseItem=F%2D09
So I will use the 2 F-10 connectors and one F-12. One is a stereo 3.5mm mini plug (to sound card) and the other 2 are RCAs (to stereo amp).
My question is where can I get the cable for it? RG6? I couldn't find a place online.
The connectors are solder type right? I have soldering experience so it won't be a problem. So if I just get the right size cable for the canare interconnects it'll be fine?
thanks
thanks
