DIY KLF-10CC in Action (1 Viewer)
Michael R Price
Nice job, Mike. I have just one question for you though. Have you considered modifying the crossover? If you sit off axis, you may get cancellation between the 2 woofers. Klipsch's center speakers use 2.5-way crossovers (one woofer has a lower lowpass filter than the other) to avoid this cancellation. It would be an interesting tweakage project :).
Or have you not noticed any off-axis problems with the speaker? I'm sure it's great in the sweet spot!
Mike Strassburg
I've listened to it in the sweet spot and in my recliner which is in a less than ideal spot and the sound is great. Very clear, detailed, and imaging seems very good although I'm probably not as critical of a listener as some are. I'm more concerned with very loud, clean, and detailed in my HT & my Legend/Tempest set-up kicks butt in that area!
I do understand the logic behind your suggestion though and appreciate the feedback. Thanks...Mike
atlanticshores
