DIY kit for SVS driver
Discussion in 'Archived Threads 2001-2004' started by Terry Flink, Aug 13, 2002.
  1. Terry Flink
    Terry Flink Stunt Coordinator
    May 23, 1999
    138
    10
    Posting here, but suspect this may get moved to the DIY section. I held on to my SVS driver when I upgraded to the improved driver. Is there a sub kit that would allow me to put the spare driver to good use?
  2. rodneyH
    rodneyH Supporting Actor
    May 22, 2001
    844
    I am going to build one, I don't know if there is a pre-built kit for it though???
  3. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    This might work:
    http://www.partsexpress.com/pe/pshow...=300-729&Did=7
    Stuff it with 3lbs or so of polyfill and cut a hole for a 4" port to tune it to 25hz and you should have what is essentially a 25-31CS in box form.
    Acoustic Visions or Rutledge Audio may also be able to make something for you. Flat kit, assembled but unfinished box, or fulling assembled and finished box.
    Finally if you have access to a drill, router and a few other basic tools building a sub enclosure out of sonotube is really quite easy. It will also be the cheapest option.
