DIY Interconnects (would this be a step forward or backward))
Discussion in 'Archived Threads 2001-2004' started by Dustin B, Aug 29, 2001.
  1. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Anyone know if this would work well for general purpose interconnects (subs, active speakers or amps, component video, composite video).
    Get these crimp on RCA plugs:
    Dayton RCA Crimp
    With one of these RG6 cables:
    RG6U or RG6U Quad Shield
    Is there any real advantage to Quad shielding? Do some interconnect no no's arise from these choices? Will these be better/worse/no different than cheap RatShack/Monster/AR etc interconnects?
  2. Peter Johnson
    Peter Johnson Stunt Coordinator
    Nov 12, 2000
    136
    Well, its just me...but if your gonna DIY, you may as well make the best, for either a little, or no more $$$.
    You will also know, that if you hear no difference, then its unlikely your ever going to hear any differences between any cables.
    Removes the element of doubt if you know what I mean.
    Make Jon Risch's cables..
    http://www.geocities.com/jonrisch/
  3. MarcS
    MarcS Stunt Coordinator
    Feb 24, 2000
    147
    Definitely, it won't cost much more to do it right the first time...
    Check out the Audio Asylum www.audioasylum.com and these guys:
    http://www.diycable.com/home.htm
    They provide cable in small quantities--actually entire kits--otherwise you generall have to buy a whole roll of cable, 100', could be more than you want initially...
    Do a search of the archives at Audio Asylum before posting a question about DIY cables...
    Here are a few other sites:
    http://www.enjoythemusic.com/etmcable.htm
    http://www.homegrownaudio.com
    http://www.geocities.com/venhaus1/
  4. Eric S
    Eric S Agent
    Feb 25, 1999
    33
  5. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    An excellent idea! Someday (I'm a procrastinator) I'm going to get at mine. Another frequently overlooked advantage to DIY interconnects is getting an exact cable length, a major plus for reducing clutter. Get the cable covers in lots of colors too. It could be fun!
    Glenn
