DIY In-Ceilings to blend with M&K fronts
Discussion in 'Home Theater Projects' started by Antony, Jun 26, 2003.
  1. Antony
    Antony Agent
    Oct 31, 2002
    29
    Hello all,
    After seeing how well my Shiva sub enclosure is coming together, I have started to think about other projects that I can build. Right now, my HT set up consists of the M&K 750THX L/C/R trio powered by a Pioneer Elite 45TX (and no, I have not experienced any shut down issues with the 4ohm loads). The rears are el cheapo Nutone 2-way in-walls that I mounted in the ceiling. They do an OK job, but I can definitely tell that there is a difference in sound reproduction/timbre during movies, etc.
    We are now in the process of building a new home (and selling our current one), and my wife is allowing me a little more latitude for rears (but not much). The Family Room/HT will still need to utilize in-ceilings for the side and rear surrounds. What I'd like to do is build enclosures out of 0.75" MDF to fit between the ceiling joists and use some DIY crossovers/drivers from PE, then fabricate my own grills (basically flush-mount a regular speaker enclosure with the ceiling drywall). I'm trying to keep cost down (or very close to store bought in-walls), while getting much better sound.
    Now rewind to the early '90's when I was into car audio competition. I bought a pair of Peerless MR-10 (1" silk dome tweets - I think) for a custom install that never happened. They are unused, unopened, and still in their original cardboard boxes. The problem is that they've been stored in my many garages/storage units throughout my moves during college and beyond.
    So I already have the MDF, tweets, and woofs, and many high-end caps/coils from Speaker City in L.A. from my old car audio days. My only expense would perhaps be buying caps/coils of other values and materials for the grills.
    Questions:
    1) Are these tweets still any good? I do have the specs, but would heat have degraded anything?
    2) Obviously I will not be able to find the exact drivers that M&K uses to perfectly blend my rears to the 750's, so can I expect these to sound at least closer than the cheapos?
    3) Any other brands I should consider?
    4) I also have a pair of Vifa 6.5" midbasses from that same era. Any thoughts? (obviously M&K has someone build their drivers to specific specs if they don't build them themselves, so I'm just looking for something as close as possible without being $$$).
    Thanks for any suggestions,
    Antony
  2. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    If I was in your shoes, I'd build a cabinet and the speakers for the surrounds, but test out their "timbre" and integration with the M&Ks before ceiling mounting them. The tweeters shouldn't go "bad" unless they were in harsh conditions. I don't know if heat alone would damage the tweeters but I guess you can always test them out.
    If you'd like to see how I installed a full size bookshelf into a ceiling you can see a shot here.
    What I did is build the cabinet to spec with a front firing port. After the box was completely painted, I added moulding to the edge, and wrapped the whole front in speaker grille cloth. This was a very quick and easy solution yet looks nice. I suppose we could have installed the speaker grill on the inside of the moulding, but that woulda costed more. [​IMG]
    I then cut a hole in the drywall and lifted the speaker up into the hole. Then, my friend attached 2 bars of MDF to the sides of the speaker so that the ends of the strips hung over 2 ceiling studs. Those strips were screwed directly into the speaker.
    Worked out well.
    Good luck with your speakers.
