raffiki
- Sep 3, 2008
- raffiki reds
I have been dying to tell someone about this. It is only a basic, cheap setup - so if you're into the top of the range then move on! The kit I purchased can be bought online, just search for "big screen tv projector". You receive all the instructions, plus a lens which is the main part of the projector.
The housing is made from cardboard, and you use your normal, portable television. The picture quality isn't fantastic, but I would be happy if I'd spent £50 on it! The image is almost 6 feet accross, and is easily watchable for several hours.
Has anyone else ever tried it?
