DIY Dual Tempest Sonotube? (1 Viewer)
JoelM
I have 4 tempests laying around from my old car system and would like to create 2 dual sono's for my living room. I have 2 SVS 25-31cs+'s running off a Sampson in my dedicated HT. I would like equal output although I heard that if done right then can sound like 2 Ultra's. If this is the case I'll move the SVS's to the living room. Any suggestions on volume/port size/port length. If you know of any good web pages for example/research purposes please post them.
Patrick Sun
The main trade-off for using the Tempest is enclosure size. What's the largest you can go on either enclosure?
Dustin B
6ft height or 6ft cubed? 6ft cubed won't cut it for dual Tempests. 6ft hieght with 24" tube will though.
Mike Strassburg
JoelM,
Here's what I recently built:
28"x54" sonotube = 480L
2 Tempests
3x3/4" MDF endcaps
2 6"x20" ports for 17Hz tune
8#'s of blanket batting for stuffing
HS500 amp 250wpc
It will hit 125+db from 25Hz on up in my 16x22 room. 2 of these would be INCREDIBLE, build it now!!! I plan to do a second one when I move to a bigger house. Good luck...Mike
P.S. These specs came straight from Dan W @ Adire.
JoelM
Mike thanks for that post!! Sometimes I need a handbook with exact measurements when doing a DIY project. To think that your pushing those babies with 250watts when they can handle 600 each. OMG I can't wait to get started.
Dustin B
Power handling is just how much the voice coils can handle without melting. Just because a sub can take 600W doesn't mean you need to feed it anywhere near 600W to realize it's full performance.
Take for instance a 340L EBS ported Tempest. It only take 210W and a 25hz signal to get the driver to Xmax (it's linear travel limit).
In a big EBS type allignment 250W is oodles of power for a single Tempest. Feeding it more just means you can move the driver to were it will start to distort badly.
Mike Strassburg
Dustin knows of what he speaks. I would think 600 watts would be TOTAL over-kill. Large enclosures don't require a lot of power and the Tempests are a pretty efficient driver. Also don't forget that you're going to build TWO of these which I believe "should" provide a 6db increase. Hope your house can take it :D
JoelM
Thanks again. I am so used to car audio that sometimes I push things to there max. I had two JBL1200's(more like 1325watts x2)pushing the 4 and had great results. Now that I upgraded to 2 Brahma's I feel that I'm still underpowing them but I'm still reaching xmax on them. :)
Michael R Price
4 Tempests? I can imagine the look on the insurance inspectors face when he sees all the cracks in your walls.
Well, good luck. I say if you already have the big amps, go for it (just watch out for bottoming in the 25-35Hz range). With 4 tempests and 600w each, you're looking at about... 128-132+ dB, I think. Just have airsickness bags ready before you start a movie.
linda19798888
