Sheldon-m
- Oct 22, 2003
I'm about to makes some comp cable but i'm having one problem with the size of the tech flex. People have been using different sizes on there cables. i have seen 1/8 for single and 1/4 for single cable. What would fit more snug. i don't want it loose. and on the comp cable i have seen 3/8" and 3/4". again i would like it to fit snug to the cable not loose. one other thing on heat shrink. i know you should use 3:1 ration it, but could I use 2:1 with adhesive.
i could not find 3:1 with adhesive. has anybody used the crimper(360-680) & die(360-688) that they sell at part express. the other crimper are way out of price range.
What do ya'll think. Thanks to all who help others. THX
