DIY audio cables
Discussion in 'Archived Threads 2001-2004' started by JimHal, Sep 14, 2001.
  1. JimHal
    JimHal Stunt Coordinator
    Aug 15, 1999
    87
    For those of you who have made your own cables out of Canare or Belden cables.
    How flexible are the cables. I have some of Radio Shacks 7ohm coaxial cable and it is quite stiff.
  2. KevinMcL
    KevinMcL Agent
    Sep 12, 2001
    27
    I'm not sure if you care, but I made the CAT-5 speaker cables, and being that it's 9 AWG, it's thick, but relatively bend-able.
  3. JimHal
    Aug 15, 1999
    87
    I was looking into that too for a while.
    Thanks for the info.
  4. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Jim,
    I have some DIY cables made from Canare connectors and Belden 1505A cable. I'd say they're just as stiff as any other RG59 cable with solid copper coductors. They also have a bit of a tendancy to coil in longer lengths. Mine are being used strictly for component video and as a digital interconnect. For regular analog audio cables I'm using the Rat Shack Gold Series stuff.
    Brian
  5. Rob Lloyd
    Rob Lloyd Stunt Coordinator
    Mar 22, 2001
    234
    I'm using the Canare LV-77s cable and being stranded, it seems fairly flexible to me. It is 2x the price of the L-5CFB which is solid core, so that would be stiffer. It makes a very nice cable IMHO.
    Rob
  6. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    I'll second the Canare LV-77 cable with the Canare connectors.
    Pete
  7. Phil Olson
    Phil Olson Stunt Coordinator
    Jun 30, 1997
    52
    I'll third the LV-77S. Very flexible with a bend radius of easily less than 6".
    Phil
