Rob Formica
- Feb 20, 2003
Ok, I've been reading around the forums planning ahead for possible music room / HT upgrades... I had a couple of questions and ideas for DIY subs and speaker stands I'd like to throw around. I have yet to build the dedicated room so this is really just in the planning stage. I'm in Canada and my budget is limited... so no Krell amps and TUMULT drivers...
I'd like to upgrade my sub (65% music + 35% movies) and I've considered dual shiva subs or a single tempest driven by either a plate amp (tempest) or a used pro amp (either tempest or shivas). After reading an article at Harmon International on multiple subs and their placement... the dual mid-wall sub set-up has intrigued me for its balanced compromises. Has anyone experimented with this? Since I was already planning building speaker stands for my rear channels and they are placed almost mid wall... what would you think of combining the two (kinda like Eric Jones did for his mains at http://www.nwlink.com/~ericj/emjspeakers/ss.html). Unfortunately this would limit optimization of either of their placements... is it still worth it? What would be the recommended height of the tweeter for the rear channels considering I'm also using them for DVDA?
Another option I've been considering is just one SVS PCi 20-39 sub and making standard DIY stands. Has anyone tested (measured) a DIY Vented Adire versus a SVS unit? Is there a web page where we can find response curves and max SPL for both under the same test conditions? I realise that it's very enclosure dependant... I'm just trying to get a general idea on how they compare... Although the SVS is more expensive initially (esp with duty and brokerage fees), it does have a much better resale value when I eventually upgrade.
Thanks...
Rob
Thanks...
Rob
