Robert_J
I documented this pretty good. You can watch it as a slide show and read the comments at the bottom of each slide. As a summary, I purchased a magnet and frame from a car audio site. I picked up the soft parts (cone, spider, voice coil, etc) from an Ebay seller. Since I didn't want to use the magnet from the blown sub, I got a surplus one from TC Sounds. It was originally for an Elemental Designs E12A.22 but eD switched suppliers and TC Sounds sold it as surplus. It's commonly called a TC9 motor and used by many companies on dozens a subs.
http://s3.photobucket.com/albums/y78/rlj5242/Custom%20Sub%201/?albumview=slideshow
I'm working on building 3 more subs that are similar to this one but I'll be using different frames and soft parts. The voice coil will be LMS (linear motor system). The voice coil uses variable windings to keep the BL (magnetic force) constant through the stroke of the cone.
