divimax HALLOWEEN s.e. - high black level??
Discussion in 'DVD' started by Sean Patrick, Sep 4, 2003.
  1. Sean Patrick
    Sean Patrick Supporting Actor
    Apr 22, 1999
    732
    now i don't want to get into a debate on the new color timing contoversy. this question relates only to the black level on the disc.
    I noticed that the black level throughout the movie - including the black bars (on the 16:9 2.35:1 image) seemed awfully bright. Scenes that should have been totally black looked more grey, and i think it brought out some artifacts. Check out the scene where Loomis and the nurse go to the asylum in the rain - some of that scene looks plain ugly and muddier than previous editions (while the daytime shots look like they were filmed yesterday).
    the new print is amazingly detailed and overall i like it, it's just this black level problem that keeps me from loving the trasfer. anyone else notice this???
    (PS - my TV is very finely calibrated and i'm watching progressive scan on a 38" 16:9 tv).
  2. Felix Martinez
    Felix Martinez Screenwriter
    Aug 27, 2001
    1,466
    28
    1,610
    South Florida
  3. Chad R
    Chad R Cinematographer
    Jul 14, 1999
    2,178
    2
    110
    Chad Rouch
    I would think that if the black level of the disc was unusually high, then you'd see a distinct difference between the disc's black bars adn the player generated ones (on a non 16x9 set). I didn't notice it and think the blacks are spot on.
    However, if you have a 16x9 TV try setting you player to 4x3 and then watch the disc in whatever standard mode your TV has (with black or grey bars on the side) and see if you can notice the player generated black bars at the top and bottom.
    Again, this is just theoretical guessing but it sounds like it'd work to me.
  4. Dave H
    Dave H Producer
    Aug 13, 2000
    5,555
    186
    9,110
    I didn't notice black levels having a problem at all.
  5. Sean Patrick
    Apr 22, 1999
    732
    maybe i need to lower my black level a notch.
  6. Dave H
    Dave H Producer
    Aug 13, 2000
    5,555
    186
    9,110
    Sean, are you using Avia or Video Essentials?
  7. Sean Patrick
    Apr 22, 1999
    732
    i'm using avia nowadays (used to use V.E. before i bought a 16:9 hdtv)....
    seriously, i guess my black level was off ONE NOTCH. I fixed the problem by turning it down by the minimum amount and it all looked great after that. tube tv settings drift, just like projection.
    never seen such a difference with one click of the remote.
  8. Topher
    Topher Stunt Coordinator
    Jun 11, 2003
    216
    I had the same issue with my Wega, just the other day I was watching Evil Dead and I thought it looked a little grey, 1 notch down on the brightness cured the problem. Made a HUGE difference. I guess the settings do drift a bit.
  9. Mitch Stevens
    Mitch Stevens Supporting Actor
    Apr 27, 2002
    581
    Sean, I had the EXACT same problem as you did. I played my original Halloween '99 and then the new version, and immediately I noticed the outside (while Dr. Loomis is in the car with the nurse) that the black level was a tad bit lighter than the '99 version. Not only that, but I too saw the artifacts that you mentioned. I however, did NOT turn my brightness down, as this was the only scene where this was noticable. Throughout the entire movie, the black level was absolutely perfect.
