shaguo
- Mar 8, 2002
I have a Toshiba TW56X81 for about 2 years now and it had great pictures until a couple of days ago when I turned on TV. The image is distorted and the red and blue colors seem mis-aligned. I tried the convergence procedure described in the Toshiba owner's manual, and no use (the red and blue lines drift away too much).
This problem happens only if I use the HD output from my RCA DTC-100 receiver. If I use S-Video or composite from the same receiver, the image and color looks fine (though not as clear as HD). It also works fine with my progressive scan DVD player. Initially I thought either VGA/Component cables or the Audio Authority VGA to Component converter is broken, because when I hook the VGA output from my DTC-100 to one of my computer monitor, the picture has no problem at all. So I bought new cables and new RCA converter and still the same problem.
Any suggestion?
Thanks a lot,
Sha
Any suggestion?
Thanks a lot,
Sha
