displaying TRUEHD or DTSHD (1 Viewer)
bambam
Grip
Ben
ok... finally got everything set up the way I wanted to with my Onkyo 605 and sony BDS P350, all with HDMI 1.3. How come it displays on my receiver it is multichannel, and doesnt actually say TRUEHD or DTSHD? Is there a way to change this, or is it just how it is shown? When I hit display on the Blu-ray player, however, it displays that it is in fact DolbyTrueHD on the television? What setting do I have wrong? I have hit the display button, and feel like I tried everything....:frowning:
Jeff Gatie
You have to tell the Sony to output undecoded direct bitstream. Do this via the setup menu. Choose Audio, then BD audio, then choose Direct instead of Mix. Note that if you choose to view any extras that utilize PiP or secondary audio, you will have to change this back to "Mix". The player is unable to mix secondary audio into the raw bitstream, so it has to decode and then mix it in, which requires the Direct mode to be off.
newyork333
