Displaying a 4:3 image on a 16:9 RPTV..
Discussion in 'Archived Threads 2001-2004' started by Tim_Mc, Nov 14, 2001.
  1. Tim_Mc
    Tim_Mc Auditioning
    Dec 4, 2000
    9
    A salesman told me today that if you use a 16:9 RPTV to view regular 4:3 tv images that the black bars on the sides will burn-in to the screen and ruin the TV. Has anyone here had any experience with this? Thanks.
  2. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Good question. Is there a way to avoid this?
    Some TV's will stretch the image sideways, but that doesn't look so nice, as I have seen it done.
  3. Henry Carmona
    Henry Carmona Screenwriter
    Feb 7, 2000
    1,299
    San Antonio
    Henry Carmona
    It is possible to burn in the bars on the sides, but if youve got your setting down (AVIA/Video Essentials), you shouldnt have to really worry too much.
    A good 16x9 will stretch a 4x3 image with very little distortion. My Toshiba 50H81 does wonders with 4x3 TV material. I never watch TV in 4x3 mode.
    [​IMG] "Charlie don't surf."
    [Edited last by Henry Carmona on November 15, 2001 at 11:45 PM]
  4. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Yeah, well, I mean, the image is distorted because the dimensions are no longer correct. The horizontal is stretched. The proportions are correct, so it is watchable, and your brain gets used to it, but its not the greatest. Too bad they don't just broadcast 16:9 with the 4:3 area being the composed shot. They could base the broadcast on the 4:3 shot, so people with 4:3 see the picture ok, but also make sure the 16:9 doesn't show anything that is supposed to be out of shot stuff. Just broadcast something that works for both. Probably way too smart.
    I guess we need DTV or more specifically HDTV for 16:9.
    I know HDTV is higher resolution, but here's a silly question. Is HDTV broadcast in 16:9?
    [Edited last by Chris PC on November 14, 2001 at 06:59 PM]
  5. RobertR
    RobertR Executive Producer
    Dec 19, 1998
    10,000
    369
    9,110
  6. Jeff D
    Jeff D Supporting Actor
    Apr 6, 1999
    604
    HDTV, high definition, is 16:9 and DTV, digital tv, isn't. HDTV is DTV but DTV is not HDTV.
  7. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    It took my wife and I only about 2 days to get used to watching regular TV in stretch mode. Now that's the only way we watch it. No big deal.
    DJ
  8. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    I never watch in 4:3 mode on my HD ready Mitsubishi... You do get used to stretch mode. I do watch as much high def. and DTV as possible though. (ShowTime HD, HBO HD, local HD)
    - Chip
  9. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    That's cool. I guess I could get used to it, whenever the heck I get an HDTV sized TV or display [​IMG]
  10. Keith Plucker
    Keith Plucker Screenwriter
    Feb 4, 1999
    1,177
    69
    1,610
    Sacramento
    Keith Plucker
    I have a Tosh TW40X81. I tried the stretch mode myself and never really got used to it. I am much happier with the zoom mode. You loose a little top and bottom but the picture isn't out of whack. To each his own.
    -Keith
  11. Bernard L
    Bernard L Stunt Coordinator
    Nov 8, 2001
    73
    uh. I thought only light/bright colors burn in your screen. but then, I could be wrong.
    I love you!! YES YOU!!!
  12. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Even if you use AVIA or Video Essentials to determine contrast you should still set it much lower to forestall uneven screen wear. My suggestion is under 50% for direct view and under 33% for RPTV/FPTV, tops. Then finish the calibrations with this setting.
    I never use stretch mode unless there are people sitting way off to the sides.
    If you are sure that the fundamental framing for a particular show is 16:9 inside a 4:3 area with filler material above and below, you can use the zoom setting.
    Other video hints: http://members.aol.com/ajaynejr/video.htm
    [Edited last by Allan Jayne on November 15, 2001 at 06:32 AM]
