Disney's TARZAN - defective version
Discussion in 'Archived Threads 2001-2004' started by Mathias Klemme, Aug 26, 2001.
  1. Mathias Klemme
    Mathias Klemme Stunt Coordinator
    Oct 25, 2000
    88
    I heard that initially, a defective version of TARZAN was released in Region 1 that had some 5-channel-sound issues. I didn't care whether my copy was one of those since I didn't own a 5.1 setup then. Well, that has changed and now I'd really like to know what version I own. Is there any way to distinguish the bad from the good? Also, why is this 5.0 "only", and not 5.1?
    Mathias
  2. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    If it sounds good to you then it shouldn't matter which version you have.
    Kyle³
    Yahoo Messenger - digitalkyle
  3. Tino
    Tino Executive Producer
    Apr 19, 1999
    10,595
    3,390
    9,110
    Metro NYC
    Valentino
    I don't think that's the answer Mathias was looking for.
    Mathias
    Which version of Tarzan do you own? The single disc version or the two disc SE?
    I believe I recall some problem with the surround sound being reversed(?) on the single disc version. Someone correct me if I am wrong.
    The 2 disc SE didn't have any problems as I recall. As for the 5.0 on both DVD's, I'm not sure why they were released that way, but it wasn't a mistake as far as Disney was concerned.
    That's how I remember things anyway... [​IMG]
    Draco Dormiens Nunquam Titillandus.
  4. Mathias Klemme
    Oct 25, 2000
    88
    I have the single disc version.
    I was just asking because I didn't want to start watching the film and then notice the sound getting screwy 30 minutes into it. Isn't there a difference in packaging or serial number like on the LEON - Director's Cut DVD?
    thanks,
    Mathias
  5. Shayne Lebrun
    Shayne Lebrun Screenwriter
    Jun 17, 1999
    1,086
    Tarzan is in 5.0; it has no dedicated LFE. This by design.
  6. Richard Kim
    Richard Kim Producer
    Jan 29, 2001
    4,385
    Not all movies today have an LFE track. Wonder Boys is another movie with a DD 5.0 track
  7. Rod Martin
    Rod Martin Stunt Coordinator
    Apr 12, 1999
    82
    Rod
    I can't recall or find the exact "time-in" but there was one particular gunshot fired by Clayton that was reversed in the surround channel, I belive.
  8. Brian O
    Brian O Second Unit
    Apr 27, 1999
    284
    I had the same thing. I just called Disney and they replaced it no questions asked, without me sending in the old one even.
    The problem was the left surround and left main were getting the same information, if I remember right.
  9. Matty P
    Matty P Stunt Coordinator
    Jan 18, 2001
    167
    A follow up question to the mention of the Leon disc above...
    What was the problem with this disc and what should I look for when I pick it up? Thanks!
    -Matt
    "As soon as you're born you start dying, so you might as well have a good time." -Cake
  10. Jamie Cole
    Jamie Cole Stunt Coordinator
    Aug 8, 1999
    211
    110
    Hi--
    There's really no way to tell whether you'll get a defective disc or not if you buy the single-disc version. The left rear and left front channels were basically the same on the defective disc due to a mastering error.
    If buying this disc now, I would absolutely opt for the two-disc SE. It's anywhere from five to ten dollars more at most B&Ms, which is really not much to pay to insure you get the right aural presentation.
    The CORRECT soundtrack is spectacular... so I would make sure to get the two-disc version and get the right thing!
    ~Jamie
  11. Mathias Klemme
    Oct 25, 2000
    88
    Thanks for all the answers guys!
    As for LEON, the first pressing had the surrounds so low you could barely hear them. Make sure you get the one that says "Newly created English 5.1" in the back.
    Mathias
