Jay H
I was setting up my father's Dish Network system consisting of
Hitachi 53 UDX series RPTV
Dish 301
Cheap JVC VCR
I bought the S-video cable, borrowed some composite cables for audio and hooked up the system as follows:
Dish301, connected to TV via S-video and RCA audio to Video 1
Dish301 connected via RF to VCR then from VCR to Ant A on Hitachi
Connect RCA video/audio from VCR to Video 2 on Hitachi.
Dish301 and VCR set to use Channel 3.
OK, my problem is that I can seem to record when sellecting Ant A and on Channel 3 when watching a dish program but I can't get the event timer to record video, I get static and white noise. I set the IR Blaster fine, the test works and the actual recording event works but when I go view the event, I get static and white noise?
Is there something else I need to check on the 301 or the VCR? The VCR is left on cause the IR blaster cannot turn the VCR on as per the manual and the tape is rewound and fine otherwise. There must be something stupid I'm missing or the Dish perhaps defaults to sending out the video/audio only on the S-video outputs and not both the RF and S-video so I'm not getting the feed from the 301.
However, I have the RF hookup going to my VCR and then to my TV as per the usual wiring diagram..
Jay
Dish 301
Cheap JVC VCR
Jay
