Dish ota help
Discussion in 'Archived Threads 2001-2004' started by JasonMC, Sep 1, 2001.
  1. JasonMC
    JasonMC Stunt Coordinator
    Jul 10, 2001
    149
    I just installed the ota module in my dish 6000. I have it hooked up to a 100" yagi I bought from Radio Shack. After installation, I scanned the digital stations in Denver, and got the 3 that are available at a minimum of 70%. I then moved my entertainment center back and then all of the sudden, I can't pick up any channels, 0%. I rechecked all of my connections, they are tight. Any suggestions?
    Jason
  2. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    After scanning and locking in on the channels, did you hit save..? Do the channels appear in the Channel guide?
  3. JasonMC
    Jul 10, 2001
    149
    After locking the channels, I did save them and they do appear in the channel guide. I'm wondering if I have a bad ota adapter
    Jason
  4. Mike I
    Jan 20, 2000
    720
    Try one more time locking into one channel a time without using the scan...If that does not work the module could be defective...
