Dish Network Question
Discussion in 'Archived Threads 2001-2004' started by Shawn_S, Feb 21, 2001.
  1. Shawn_S
    Shawn_S Stunt Coordinator
    Mar 14, 2000
    62
    Hi all. I'm about to get set-up with Dish [​IMG] Quick question: If I buy a system from an online retailer, who would I get to install it? Since they have the rebate special now, I would like a professional to do it and not deal with it.
  2. Franklin_C
    Franklin_C Auditioning
    Aug 31, 2000
    9
    If you go the Dishnetwork web site and pull up a list of dealers in your area, you should be able to find someone who would install it. Dishnetwork also has installers in some areas, not sure if they would offer to do install if you do not buy direct. Otherwise go to the Satellite TV section in your yellow pages. You should be able to find someone there also.
