Bill Austin
- May 8, 2001
I am considering Dish Network and I have a HDTV ready set coming in two weeks Toshiba 55hx70.
I have read thru the site for dishnetwork and saw the model 6000 unit has the HDTV decoder built into it, however I noticed another section of the webpage that talked about needing a second dish for HDTV reception?
I want to try and take advantage (as much as possible) the freebies they are offering currently - free install and some free basic equipment that I am hoping I could just pay the difference for stepping up to the 6000 on, and I plan on picking up a pretty full lineup of channels, but it's the hardware I am not sure about.
I know I'd want the 6000 for the HDTV decoder built in, I know I need at least one dish for the regular bulk of the channels, but it mentions another dish being necessary for the HDTV broadcast channels...
So I will have 2 separate dishes on my balcony? Or is the other antenna that is mentioned something that gets attached on the same main dish as a branch off it or something?
Just thinking in terms of mounting, I have never seen 2 dishes side by side on a house or apartment, so I was hoping it was just my misunderstanding that 2 separate dishes would need to be installed.
As you can see I am still somewhat unclear, and have spent some time reading the webpage but had not gotten a full grasp of what I would need exactly to get the HDTV and the regular channels they offer.
Lastly, this is for those who had cable & went to dish Network, even better if you live near Chicago.
Do you notice a difference in just the basic service quality of picture (not HDTV stuff), my current cable provider at&t quality wise the picture is terrible on the lower channels, fuzzy, grainy, ghosts etc, & I have repeatedly tried to get them to fix the problem with no resolution (that's why I am looking into Dish Network) does Dish Network provide a somewhat stable clearer picture than standard cable? I understand rain and snow can interfere at times but on the whole just curious of input on difference in quality for basics.
Bill
Bill
