DennisP
- May 5, 2000
Can anyone confrim that if you have a Dish system installed with the HD receivers and you take the local stations as a part of the Dish package.....AND the locals in your area are being broadcast in HD over the airwaves...will these locals be received through the Dish programing in HD or SD?
I know that you can install a roof top antenna to receive these signals in HD using the Dish receiver.....that's not what I'm asking.
Are these local signals that are coming through the Dish programing package going to be in HD or not.
I talked to one person who works for Dish and said they would be in HD on the Dish if they are in HD locally. I want to confim this to determine if I will need to purchase a roof top antenna in addition to the Dish.
