chadahren
- Jun 24, 2003
Hello all,
I am frantically searching for a resolution to this one - I just had Dish network installed and have the 811 receiver connected to my Samsung TSL2793HF - It's a few years old but HD compatible. I get a fine image with S-video or composite hookups but component hookups (this TV has no DVI input) create an effect where the image is doubled and shows both side-by-side with some discoloration. This is the first time I've used a HD source so I'm not sure if there is some setting within the TV I am missing..component cable feeds from my PS2 or DVD do not produce the same effect, but I get it from the 811 regardless of the cable (Dish-provided or Monster). Does anyone have insight?
thanks,
chad
thanks,
chad
