Dish 811 HDTVR Question
Discussion in 'Playback Devices' started by GregCole, Apr 5, 2004.
  1. GregCole
    GregCole Extra
    Feb 13, 2004
    24
    Does my new dish 811 upconvert everything to 1080i? If this is true, then do I only need to calibrate my 1080i and 480p inputs, or do I still need to do 480i?
    TIA-Greg
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    It can, but remember if it looks like crap at 480i, it won't look better at 1080i [​IMG]
    IMO, you would want to calibrate whatever inputs are utilized.
    Cheers,
  3. GregCole
    GregCole Extra
    Feb 13, 2004
    24
    Thanks for the reply John. I want to do a ISF Cal., but money is tight and since I use my 811 for all TV, could I just skip the 480i input and save that $ since it upconverts?
    Thanks again- Greg
  4. Nathan_R
    Nathan_R Supporting Actor
    Dec 4, 2000
    717
    Yes, you can save some cash this way-- I don't think it will be much, though. As for the 811, everything will be upconverted to 1080i if you set it up that way.
