flabotinum
- Nov 17, 2008
- brian
My first post and im getting right into it, ha...
i have a question for anyonw willing to help. I emailed my cable tv company about it and got a response from them. Ill post my inquiry to them and their response. It has all the pertinent info for anyonw willing to assist me. FYI, im not an expert, and yes i did purchase the more expensive HDMI cable before i read on here how it is a waste. Anyway...here it is:
MY EMAIL TO THE CABLE COMPANY:
"I just purchased a 1080p HDTV at 120Hz. I have the scientific atlanta explorer 4250HD box. I also have an ultra high speed HDMI cable (10.2 Gbps for 1080p+ at 120Hz) from monster that is connecting the box to the TV. However when i choose the video output for the HDMI on the screen it says 1920x1080i @ 60Hz. Also on the front of the box 1080i is lighted up. I have 2 questions - Isnt it supposed to be 1080p, if so why is 1080i lighted up. Also, it should be @ 120Hz. Since i have the hdmi cable and TV that can run on 120Hz, im assuming the problem is the box. Any advice?"
THEIR RESPONSE:
"The highest format broadcast is 1080i and thus the reason this appears on the cable box. 1080p formats can be found on Blu-ray DVD.
The signal that you are receiving comes in at 60 Hz but your 120 Hz television will allow you to receive a brighter and crisper picture."
So it seems that getting a 1080p TV is pointless unless you have blu ray or a hd gaming system. As far as tv signal is concerned (at least my cable company), 1080i is the highest.
Ok im fine with that....however the second part is a bit confusing. They are saying their signal comes at only 60Hz but my TV's 120Hz capability will improve it. Does this sound correct? Also is it normal that an HD cable signal only comes at 60Hz, or is it just my company?
THANKS
THEIR RESPONSE:
THANKS
