bubblebuddyi
Grip
- Jun 26, 2010
- james
I've been in the home theater crowd for a couple years now, and I'm just not satisfied with the results I'm getting from my own system I've built over the years. A little about my system and setup:
First off, my room SUCKS! I'm in limited space with little room to move things around, so I did the best I could. Here's how my setup works.
Yahama RX-V665
Polkaudio TL150 speakers
Klipsh Subwoofer, I believe the 450W (complete overkill)
42" Panasonic TV
All my speakers are wall mounted, angled and tilted pointing towards my seating position (couch).
My TV is about 9ft from the seating position. The front channel speakers are measured at about 8.5ft to the seating position, with the subwoofer at 8ft. The rears are measured at R-4.5ft and L-5.5ft. All the speakers are measured 4.5ft from the floor, except the center which is a little above 3ft, just under my TV.
The problem is that my setup does not have a surround feeling, except at very high volumes. I have all speakers properly setup using a sound meter, with the surrounds a could db higher. The only thing I could think of is that the surround speakers are behind my seating position. The are positioned wider than my couch, and pointed and angled at my couch. Also, the bass is terrible, as soon as I sit down the bass is gone. I can feel it, but that's about it. And if I stand up, I can hear it again. I tried changing the phrase, but it doesn't make a difference.
I don't know if I'm missing some important settings or my setup is just crap. Any tips would be great .
I use this mostly for video games and movies.
Yahama RX-V665
42" Panasonic TV
