Sean Patrick
- Apr 22, 1999
while info on disabling SVM on Toshibas and Sonys can be found pretty easily, i'm getting an RCA F38310 tomorrow and would like to know how hard it is to disable the SVM in the set. Has anyone here been able to figure out how to do it?
luckily the SVM isn't too bad on the set to begin with. Someone told me to turn the sharpness down to 0 on this tv but that doesn't sound right. If that IS the solution, though, I'll try it
