steve jaros
You don't need to open up the back and pull a wire. Just hit the menu button, and go into the *movie* mode (not to be confused with the film/video option on the second menu screen). This disables SVM.
Once in "movie", modify your settings to the values you want (contrast, color, brightness, etc. When you begin to modify these values, the TV will switch to "preferences" mode, BUT your SVM will stay disabled. *Save* these values, and you are set.
If you pull up your menu and immediately go into "preferences" mode without going into "movie", you will not disable SVM...
History can be cruel in its brevity of words
