Scott_R
- Jun 29, 2000
Can anyone tell me the best way? When I open the front, there are three boards, one on each gun. There is a pair of wires (yellow and white) with a connector going to each board. I'm pretty sure from looking at the service manual that these connectors are what I need to unplug. Can anybody confirm this? The left and the center one should be easy to unplug but the right one is going to be tight. Or.... should I just unplug the main SVM power supply? I think you have to go into the rear for this. Can anybody tell me exactly where the plug is? Which is the best way to disable this?
THX
THX
