Scott.Lacy
Grip
- Jan 21, 2003
Hi all,
OK, I've got some questions that might make me sound pretty stupid, but I am stupid, so that's ok. Any help with this would be greatly appreciated.
My sister-in-law just got a good deal on a HD DirecTV package and had it installed on Friday. Basically, the setup is as follows:
Oval Triple LNB dish on the roof with two cables coming out of it....feeding to the basement.
One cable goes to the HD tv (also in the basement) and is hooked up to a HIRD-E86 for HD DirecTV.
The other cable is fed through the ceiling of the finished basement to the upstairs standard TV and connects to a generic receiver. Everything works fine.
As soon as it was installed, we went to CC and she bought a DirecTivo, a 4 port multi-switch and 50 ft. of RG6 cable.
When we got back to the house, I hooked both feeds from the dish into the multi-switch, then hooked up three feeds (1 for the HD downstairs, and 2 for the Tivo upstairs). After I was finished connecting everything, the HD TV worked fine, but the upstairs TV cannot acquire a signal on either the Tivo or the Generic receiver. I've been doing some research and it seems as if the oval dish has a multi-switch built into it. Does this mean that I do not need the multi-switch and all cables should be run directly from the dish to the receivers? If not, how can I make this work?
As I said, I'm not the sharpest tack on the shelf when it comes to this stuff, so thanks in advance for any advice.
Scott
Scott
