directtv tivo question (1 Viewer)
Jeremy Swenson
using tivo can you just push the button to record and thats it? including network channels that you get off air?
Rachael B
Knocksville, TN
Rachael Bellomy
That's about it. There's other ways to record also, by title, season-pass, time, channel, ect. Are you looking at SD or HD? In either case, you can always hit record for what you're watching. Recording, temporarily, essentially begins everytime you change a tuner. All the models, SD and the HD box all have two tuners. Really, you're just instructing that the current recording/s are saved.
Jeremy Swenson
my main question is if it works the exact same for satelite channels and off air stuff, this is for my dad, and i want it as easy as possible, without switching to a different input if possible
Rachael B
Knocksville, TN
Rachael Bellomy
If it's the HD model, yes. If it's the SD model, yes, if you buy the local channels, it can't record off the air. The SD model has 2 satelite tuners. The HD model has 2 satelite tuners and 2 OTA tuners.
Grant B
Jeremy
Rachael is always right!
Just a little to add. I had originally a stand alone Directv box and a seperate TIVO. I found that combination akward and a real problem for my wife to use. I was trying to ween her off me as her own 'personal recorder'.
Quality was disappointing too.
Sold those and got a 2 tuner Directb box and it works great!
Cheers
Robert_J
Mississippi
The easiest thing to do is set up a Season Pass. Set it up one time and forget about it.
Did you know that PVR's had their own section now? link
-Robert
PtleKraken
