Jim Golden
- May 8, 1999
I can't seem to get a Dolby Digital signal from my DirecTIVO. Although I've had the unit for 8 months, this is something I just noticed.
Before you ask, the only audio connection I'm using is the optical connection. I also have my audio options set to "yes" to enable a Dolby Digital connection whenever it's available.
My Directv ABC channels often display a Dolby Digital symbol, but I'm not receiving a Dolby Digital symbol (just a PCM). Is something wrong with my unit? Is it possible for a unit to output a PCM signal and not output a Dolby Digital signal? Should I call product support?
Thanks in advance,
Jim
Thanks in advance,
Jim
