Frank Zimmerman
Grip
- Jan 15, 2002
whitch way does the arrow point in the reciever or my amp...need alittle help here.......
Directionality: All cables are directional, from hardware store electrical cable to the finest pure silver cables. All AudioQuest cables are marked for direction. With other cables it might be necessary to simply listen to the cables in one direction and then the other. The difference will be clear-in the correct direction the music is more relaxed, pleasant and believable. While cable directionality is not fully understood, it is clear that the molecular structure of drawn metal is not symmetrical, providing a physical explanation for the existence of directionality.Well, I think that's enough!
With other cables it might be necessary to simply listen to the cables in one direction and then the other. The difference will be clear-in the correct direction the music is more relaxed, pleasant and believable. While cable directionality is not fully understood, it is clear that the molecular structure of drawn metal is not symmetrical, providing a physical explanation for the existence of directionality.Puhhhleeeeez!
Where is Chu when you need him?
BGL
While cable directionality is not fully understood, it is clear that the molecular structure of drawn metal is not symmetrical, providing a physical explanation for the existence of directionality....and I though it was a well known fact that annealed metals were isotropic.
Monster Cable makes our Unbalanced cables, "Semi-balanced" by utilizing twisted pair cable. We use one conductor as the positive lead, terminated to the Tip, one conductor as the negative lead, terminated to the sleeve, and we terminate the shield to the Source side of the cableSo this isn't run-of-the-mill coax, this is a 3-conductor cable where the shield conductor is separate (and insulated) from the signal carrying conductors. You're right, if the shield is also the ground connection (as is the case with most coax), this won't make any difference. In fact, it won't work, the shield/ground conductor must be connected at both ends for the interconnect to pass any signal.
I think having a shield that's separate from the ground conductor has other benefits, especially with RFI rejection. You can't do this with commercial gear and RCA connectors, but if you build your own preamp/amps/interconnects, you could connect the cable's shield directly to the chassis/earth, while the 2 signal conductors go to hot/ground of the signal circuitry. This way, any RF currents induced in the shield find a direct path to safety earth, and they don't ride on the signal ground. I'm sure that can't hurt the sonics/functioning of the circuit, and in some cases may even help things a little.
We use one conductor as the positive lead, terminated to the Tip, one conductor as the negative lead, terminated to the sleeve, and we terminate the shield to the Source side of the cable......it looks to me like they’ve overlooked a fundamental of electronics, namely that continuity is continuity (at least for the sake of this discussion). If you lift the shield at one end yet it’s connected through a signal wire at the other end, you’ve gained nothing.
Wayne A. Pflughaupt
