Direction of RS Meter
Discussion in 'Archived Threads 2001-2004' started by Bob_M, Dec 17, 2001.
  1. Bob_M
    Bob_M Stunt Coordinator
    Apr 3, 2000
    194
    Hi All,
    I have a question on using the test tones from AVIA with the RS sound meter. Where should I point the microphone when setting speaker balance? Straight up, pointing toward the front or pointing toward the rear or other? I asumme
    you don't move it once you pick a direction as the pan moves around the room.
    Thanks Bob
  2. DougRuss
    DougRuss Stunt Coordinator
    Oct 3, 2001
    195
    I think the best way would be to point it at a slight forward angle upwards(towards the ceiling) ?
  3. DavidMich
    DavidMich Stunt Coordinator
    Nov 27, 2000
    177
    From what I have heard, you want the meter to be positioned so that it would be centered in the "sweet spot" at ear's height. Then point the meter towards the front of the soundstage (like your ears would be) and angle it up at a 45 degree angle. Do not move it as the tones pan from each speaker. (That is, do not aim it at the speaker)
    Right or wrong, I did mine this way, and it sounds fine.
  4. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    I can't remember where I heard/saw this from, but I remember seeing that you're supposed to point it straight up. Obviously, placed where your head would be at your listening spot.
    Maybe Guy of Avia could comment if he sees this...
  5. Bill_Weinreich
    Bill_Weinreich Second Unit
    Sep 25, 2000
    317
    Most of my materials state the same thing. Hold the meter at the main listening position (I prefer using a tripod mount to keep me out of the way). Place it at about head hieght, and aim forward towards the junction of the front wall and ceiling at center.
  6. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    The object is to get the angle from each speaker to the center axis of the SPL meter's mic to roughly the same off-axis angle, since the mic does have some directionality issues.
    The ceiling/front wall junction rule is a fairly good rule of thumb, but if your center speaker is mounted fairly high, it can throw you off. Basically, imagine a line coming out of the microphone... You want to point that line so that the line to each individual speaker is at about the same angle. In my room, I've found that tilting the meter down about 20-30 degrees from vertical brings each speaker within 10 degrees off-axis angle and gives me the best sounding calibration.
  7. Phil Iturralde
    Phil Iturralde Screenwriter
    Oct 7, 1998
    1,867
    Video Essentials and Dolby Labs recommends the following, . . .from their:5.1-Channel Production Guidelines PDF document
