Direct TV signal is not very good ?
Discussion in 'Archived Threads 2001-2004' started by Samson, Aug 27, 2001.
  1. Samson
    Samson Stunt Coordinator
    May 15, 2001
    76
    My DirectTV signal is not very good. Images are sometimes blurry and not very sharp or detailed. I have a Sony 35S42 TV and it's incredible when I'm watching DVD's. So it doesn't seem like that the problem is the TV. Could you tell me what the problem could be ? Or is the DirectTV signal really this bad ?
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    It should be better than cable TV. I'd suspect that you have a bad cable somewhere. This sounds like a new system. If it was professionaly installed I'd call them back, and if you did it you might want to start swapping cables. The ones outside all need a rubber jacket over the connectors, or water WILL find its way inside of the cable. I hope this helps.
    Glenn
  3. Eric Paavola
    Eric Paavola Auditioning
    Feb 12, 1999
    9
    My DTV signal is very good. I have a Toshiba 57H81 and the picture is marvelous. My cable is quite good also. I was surprised because some folks say cable is not very good to watch on some large RPTV. As Glenn said it is possibly a problem in your equipment.
    Eric
  4. Larry Schneider
    Larry Schneider Second Unit
    Aug 9, 1999
    356
    Or the source material. Also, some channels seem to be more highly compressed than others.
  5. LDfan
    LDfan Supporting Actor
    Nov 30, 1998
    724
    Any DirecTV picture problems can usually be attributed to the levels of compression they use. The best picture quality to the worst can be found on these kind of channels,... PPV, Movie channels (HBO, Starz, etc..), sports channels, all the way down to the locals.
    Jeff
  6. MikeRa
    MikeRa Auditioning
    Jan 11, 2000
    11
    Samson,
    Try this quick test. As others have noted that Direct is overcompressing stations, tune to channel 100. This seems to be their Promotion station, The one that is played in electronic stores to make folks like you and I say WOW satellite is awesome. On my system channel 100 plays pretty well, especially when compared to TNT. Why am I watching movies on TNT? Good Question.
    My 2 cents, Good luck.
