Chuck Paskovics
- Feb 26, 2002
I'm contimplating a direct tivo unit. Since the tivo is built into the dss receiver, is it possible to record not just dss signals, but also the cable signal? So if there is something on my local channels will I be able to record it to tivo or am I limited to only dss signals?
If so, can I record both a dss signal and a cable signal at the same time (with the duel boxes)?
