direct subwoofer input question
Discussion in 'Speakers & Subwoofers' started by Matt Hobbes, Mar 21, 2004.
  1. Matt Hobbes
    Matt Hobbes Agent
    Sep 9, 2002
    48
    I've been looking at Aperions recently, but I had a question about their review on cnet stating no direct subwoofer input on the asperion speakers ...
    When they say no direct subwoofer input are they referring to not having a line level input on the sub (which it does), or the fact that you can't shut the sub's built-in crossover off? Or that it doesn't have line level inputs on the front/center/surround speakers. Is a line level input different than a direct subwoofer input?
    thanks
    sorry, can't post urls yet; cnet review is at their homepage
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    Are you right about what?
  3. Matt Hobbes
    Matt Hobbes Agent
    Sep 9, 2002
    48
    I reworded the question...sorry if it was confusing.
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,130
    40
    6,610
    Katy, TX
    Wayne
    Thanks Matt, much better!
    Okay: “Direct” means the internal crossover is bypassed, or it does not have one at all. A line-level input is the same as a subwoofer input.
    Hope this helps.
    Wayne A. Pflughaupt
  5. Matt Hobbes
    Matt Hobbes Agent
    Sep 9, 2002
    48
    ok, there's just no way to bypass the subwoofer's internal crossover.
    thanks!
  6. Mitch_J
    Mitch_J Stunt Coordinator
    Oct 16, 2003
    129
    There is no way to bypass the internal crossover. But it is highly adjustable from 40hz to 160 hz, combined with it's polarity control and gain. makes it a pretty easy sub to place.
    If you're thinking of picking this sub up I recommend it.
