Dipoles - Distance From Back Wall!?
Discussion in 'Archived Threads 2001-2004' started by AaronG, Jan 29, 2002.
  1. AaronG
    AaronG Stunt Coordinator
    May 15, 2001
    185
    Hi guys,
    Sorry, I've kind of asked this as part of other threads, but I need an answer right away (I'm pre wiring, the dry wall is up, and I'd like to know before they start taping).
    Is 2.5' from the back wall enough distance for using dipoles? This is about 2' behind the main listening position.
    Aaron
  2. Ned
    Ned Supporting Actor
    Feb 20, 2000
    838
    Can they be further forward so they are more inline with the listening position? 2.5' is fairly close but you'll still get decent diffusion. Mine are about that far from the rear wall and they work as designed.
  3. AaronG
    May 15, 2001
    185
    Thanks Ned,
    I'll see if I can move them up a foot but that means shifting the sconces as well.
    Anyone else?
    Aaron
  4. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    2ft is the minimum recommended distance for dipoles from the back wall. They need space to work properly.
  5. GarryW
    GarryW Stunt Coordinator
    Jun 27, 1999
    162
    My ADP-350's are going to be about 8'0" from the back wall. I hope that's not too much, but there's not much I can do about that. I am powering them with two Marantz Monobloclks rated at 125w/pc.
  6. Ned
    Feb 20, 2000
    838
    Aaron- move up a foot? I meant move them a bit towards the front of the room (horizontal change) to clarify. Although they should be a good 2-3' above ear level as well.
  7. jason celaya
    jason celaya Stunt Coordinator
    Jul 1, 2001
    143
    does the 2 ft. rule apply to tri-poles as well?
  8. AaronG
    May 15, 2001
    185
    Hi Ned,
    By up I meant forward.:b
    They will be about 2.5' above the main listening position and around 3.5' from the back wall.
    Is it going to be a problem that a small wall sconce will be about 1' in front of the speaker?
    thanks,
    Aaron
  9. CapnSharpe
    CapnSharpe Stunt Coordinator
    Dec 17, 1998
    165
    Whoa - wait a second...I thought dipoles could be placed to the sides of the listening position and not behind the listening position. I don't have any room behind behind my listening position and the dipoles are only 2 or 3 inches in front of the wall. Am I going to burn in HT hell for this or what? [​IMG]
  10. Ned
    Feb 20, 2000
    838
    This is the ideal positioning.
    [​IMG]
  11. Scott Page
    Scott Page Stunt Coordinator
    Sep 6, 2001
    196
    Theresa,
    Dipoles can also be put a foot or two in front of the ears with no problems. If you are that close to the back wall, I'd move 'em up to let em breath. They need space to create the non-localized effect. Of course the width of the room has a bearing too. If the room is very narrow, then you may get negative effects from going up to 2 feet forward. With a wider room, you have more flexability in the placement.
