Christian dds
- Mar 27, 2002
I am upgrading to 7.1 surround dts-es and THX ultra and would like some speaker advice. This system will be for movies only, (I have a seperate music system in a listening room). With 2 front, 1 center, 2 surrounds and 2 back surrounds would you recommend dipole, Bipole or direct radiating surround and back surrounds or a combo of both? Thanks for your advice.
The room is 16' wide and 23' deep with the viewing possition currently about 8' from back wall. There are very few limitations as to where I can place seating or speakers(3 blank walls and 1 long wall with door at back and fireplace on wall). It's a rectangular dedicated home theater room so almost any configuration is possible within space constraints. After I decide on what surrounds and rear surrounds, placement is next....suggestions welcome.
Would 1 or 2 rear wall surrounds be a better match with two side surrounds? Would two smear the discrete effects by matrixing the L&R surround signals?
If I am placing 6 Paradigm Reference Studio 20's and a Studio CC (all monopole) and Paradigm PW2200 sub and Denon 3802, what is the ideal location for each in my 23' (7m) deep x 16' (4.87m) wide x 8' (2.44m) high room. 3 walls are blank and the arrangement is very flexible (no windows).
