James_EJr
- Jun 3, 2003
Should I purchase another set of Paradigm's ADP-170s for the surround rears to go along with the surround sides or keep my Paradigm Atom speakers as my surround rears? Thanks.
Go look at any freq response plot for a direct radiator. Now look at the off-axis plots. Just as the sun rises each day in the east, the high freqs are rolled off as you go more and more off-axis.Here's another example:
http://www.hometheatermag.com/showarchives.cgi?25:3
I believe I read in a speaker review that if you use direct
radiating speakers as side surrounds, they should be mounted downward toward the listening position, but an angle toward the front of the room. This would give you more of an ambient soundstage. True?
