Dimmers and HT
Discussion in 'Home Theater Projects' started by itai, Apr 30, 2004.
  1. itai
    itai Stunt Coordinator
    Jan 23, 2002
    221
    Hi all
    I've noticed interferences on the TV screen, (a new Phillips 36" 16:9 beast) when the light dimmers in the living room (where the TV's at) are working.
    if they're closed shut, or at full strength, the picture is clean. It shows when either of the dimmers, even across the room, is engaged. (Gevis dimmers)
    the TV shows crawling dots and slight noise. you can see it when the DVD is stopped, and sends a black picture to the TV.
    The electricity was renovated (as the whole apt), and was upgraded to triple phase (sorry, i don't know the exact term in English).
    Any help will be appreciated!
    Thanks.[​IMG]
  2. Ethan Winer
    Ethan Winer Stunt Coordinator
    Apr 6, 2004
    95
    Itai,
    Solid state dimmers are notorious for this. See the "Hum and Buzz" article, 4th in the list on my Articles page:
    www dot ethanwiner dot com/articles.html
    In particular, see the section that explains how to use variable transformers as dimmers. I'm not sure what voltage you have in Israel, but the concepts are exactly the same.
    --Ethan
  3. itai
    Jan 23, 2002
    221
    Thanks Ethan
    I guess I'll have to install variable transformers as you explain.
    We have 220v in israel. I have an uncle who's an engineer, he will read your explanations, as I've no clue about electricity.
    He also (as you suggest) installed a regular switch to turn the dimmers on and off simply, and he'll probably enjoy reading your article.
    Thanks!
    ps, can it harm the equipment? (the tv?)
  4. Ethan Winer
    Apr 6, 2004
    95
    Itai,
    > can it harm the equipment? (the tv?) <
    Do not use a variable transformer with the TV! It's for dimming the lights only, and only for use with incandescent (filament) light bulbs - not flourescent bulbs.
    --Ethan
  5. Derrik Draven
    Derrik Draven Supporting Actor
    Dec 7, 1998
    935
    Chris
    I have 4 rows with 5 halogen track lights on each row, overhead in my ht.
    Originally, I put sliding dimmers on each light switch but, the noisy grrrrowwwwllll, that the transformers would make when adjusting the lighting, made me just say "screw it", and I put on/off switches in instead. Total silence now.
    Take out the dimmers if you can.
  6. itai
    Jan 23, 2002
    221
    i'm not using the dimmers with the tv!!!! that's not what i meant...
    i meant, can the (expensive) tv set be harmed by the noise in the current (seen on its screen).
    the tv is plugged into a separate socket, in the same room as the dimmers.
    thanks for your help anyway!
  7. Ethan Winer
    Apr 6, 2004
    95
    Itai,
    > can the (expensive) tv set be harmed by the noise in the current <
    Probably not.
    --Ethan
  8. MikeWh
    MikeWh Second Unit
    Mar 3, 2003
    407
    Nice article, Ethan.
    itai--- in addition to Ethan's information in the article, you should be familiar with one of the most frequently mentioned design suggestions for electrical wiring in a home theater--- it is HIGHLY suggested that you place your audio and video equipment on a separate phase from any circuits with dimmers on them. Of course, it looks like you are in a newly renovated apartment, so it's apparently too late for you....
    As far as your issue is concerned, you may also be able to replace the dimmer(s) with higher quality dimmers. This may be a hit-or-miss solution however. I have three Smarthome dimmers that are all the same model, but one of the dimmers has a very slight, but noticeable hum in it. Apparently, you may find different reactions from individual dimmers and their specific loads.
  9. itai
    Jan 23, 2002
    221
    thank you guys,
    yes, we learn things the hard way...
    [​IMG]
  10. John Sayers
    John Sayers Auditioning
    Apr 9, 2004
    5
    itai - here's a link to the Luxtrol var- trans dimmers.
    www dot superiorelectric dot com/WEB_voltage/luxtrol-c dot pdf
    cheers
    john
