Dimmer switch by home stereo?
Discussion in 'Archived Threads 2001-2004' started by Eugene Hsieh, Aug 7, 2001.
  1. Eugene Hsieh
    Eugene Hsieh Supporting Actor
    Jun 30, 1997
    550
    Hi.
    Near the stereo system I have a light switch which I would like to put a dimmer switch on. Will it affect the system?
    If so, which are the best ones to use? (Not putting a dimmer is not an option.)
    Eugene Hsieh, VisorCentral FAQ Editor
    1000 km on a tank of gas??? Check out the Prius and drive the future now!
  2. SamRoza
    SamRoza Stunt Coordinator
    Apr 27, 2000
    186
    I don't think you need to be especially careful with dimmers as long as they're controlling incandescent lights, and not Motors, fluorescents or halogens.
    For Motors(IE, fans), I think you need to use a capacitive dimmer. You can't control Fluorescents, and I don't believe you would want to use one for halogens at all(but I may be wrong).
    Sam
  3. Eugene Hsieh
    Jun 30, 1997
    550
    Hmmmm... The switch would be for a wire hanging low voltage/low wattage halogen system.
    The transformer puts out a low DC voltage through two plastic covered wires which hang over the room, and can handle up to 150 Watts. I can attach up to 7 20 Watt halogen spot lights. (2-3 lights are for the dining room table, and the rest light up art on the wall.)
