Dimension Films' DVD problems with HDTV
Discussion in 'Archived Threads 2001-2004' started by Chris Joyner, Mar 8, 2003.
  1. Chris Joyner
    Chris Joyner Stunt Coordinator
    Mar 6, 2003
    53
    I have 60" widescreen HDTV (Phillips Magnavox) and a JVC XV-S502 DVD player. I have 2 Dimension Films' DVD's "From Dusk Till Dawn - Collector's Edition" and "Highlander: THe Final Dimension". Both of them aren't filling up my widescreen TV. Both are formatted 1.85:1 , but instead of filling up the screen, they look "zoomed out". There are black bars on all 4 sides of the screen. The picture ratio is proportionate to the TV screen, so I can "zoom in" and it fills the TV then, but the Zoom icon stays on (and the picture is kind of grainy). I've tried formatting the DVD player and the TV, I've even called both companies and Buena Vista DVD's technical support, but no answer there. Has anyone run across this problem before? I sure would appreciate it if someone could enlighten me on this. Thanks.
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    Highlander 3 is 2.35:1, and it's non-anamorphic, I guess From Dusk Till Dawn is too
  3. Adam Tyner
    Adam Tyner Screenwriter
    Sep 29, 2000
    1,410
    Neither DVD is enhanced for widescreen televisions.
  4. Matt Stone
    Matt Stone Lead Actor
    Jun 21, 2000
    9,063
    Both of the above posters are correct. You need to watch non-anamorphic dvds in zoom mode.
  5. Kyle McKnight
    Kyle McKnight Cinematographer
    Mar 8, 2001
    2,504
    Yep, it's not the DVDs fault, its the way you have your player/tv set up.
  6. Nick Graham
    Nick Graham Screenwriter
    Oct 16, 2001
    1,406
    Yep, as the above posters said, you will have to zoom, as I do. From Dusk Till Dawn really chaps my hide too, as the Collector's Edition is the second release of that film, released over a year (if not two, can't remember) after the release of the original barebones, non-anamorphic disc. So, Disney/Miramax/Dimension had plenty of time to do an anamorphic transfer, and no excuse not to, but that didn't stop them from just rehashing the original transfer.
  7. Malcolm R
    Malcolm R Executive Producer
    Feb 8, 2002
    13,130
    814
    9,110
    Malcolm
  8. Jeff Kleist
    Dec 4, 1999
    11,267
    Tech support people have a procedure book, basically they follow a script. If they don't have a procedure they don't know
  9. Malcolm R
    Feb 8, 2002
    13,130
    814
    9,110
    Malcolm
  10. Jeff Kleist
    Dec 4, 1999
    11,267
    I'm doubting that they consider widescreen televisions a widespread enough "problem" yet
