Digital tuner/reciever-do they improve DVD players
Discussion in 'Archived Threads 2001-2004' started by Tim Sheils, Mar 12, 2003.
  1. Tim Sheils
    Tim Sheils Auditioning
    Sep 4, 1999
    2
    Hi
    I have a tiny budget and started with a samsung HDTV and a Pioneer progressive scan DVD. I don't watch cable or broadcast TV, only DVDs. As far as picture quality goes, do I need a tuner or receiver to obtain the best results for playing a DVD disc?
  2. Rob Dawn
    Rob Dawn Stunt Coordinator
    May 8, 2001
    116
    A receiver won't affect your picture quality at all.
    The receiver would be your first step in getting 5.1 surround sound though.
    Rob
  3. Tim Sheils
    Sep 4, 1999
    2
    Thanks Rob
    Yes, for sound I know I have a ways to go, but its good to know that at least my picture quality will be up to snuff (I'm using component connections). Am I right that my picture will be 420p, or will it be better?
  4. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Rob is correct in terms of A/V Receivers. However, I thought at first you were talking about digital HDTV tuners/receiver for watching HDTV Over The Air. In which case if that is your question, then no, this will not help DVD playback at all. Now, in terms of getting the best picture, make sure your DVD player is set to output progressive. It doesn't know to do that automatically, so you need to rear your manual and find out how to do that. It may be a switch on the back, I've seen that, and more likely a menu option that you need to turn on.
  5. Rob Dawn
    May 8, 2001
    116
