Digital Signal
Discussion in 'Displays' started by Chris Huber, Jun 6, 2004.
  1. Chris Huber
    Chris Huber Second Unit
    Jan 2, 2003
    416
    http://www.circuitcity.com/detail.js...&oid=80976&m=0
    I picked this TV up for a really great price. I don't have digital cable cause I really only want to watch movies. But, say a show like ER is on. It says presented in High Definision. Does my built in digital tuner pick that up over a regular cable conection? Or do you actually have to have digi cable to get that?
  2. Andy_Hamric
    Andy_Hamric Stunt Coordinator
    Apr 14, 2004
    54
    What you are getting over analog cable is the standard definition picture. If you want a Hi-Def picture, you need to have something that's feeding you a Hi-Def picture. An antenna will, and cable will if the cable company is transmitting the HDTV signal on the cable. In the investigating I've done, usually digital cable does not automatically come with the Hi-Def channels, you have to buy an upgrade package to get those. Usually most of your locals plus a couple Hi-Def channels like DiscoveryHT, ESPN-HD or something like that.
    I have WideOpenWest and they don't offer my UPN station in Hi-Def.
  3. Chris Huber
    Jan 2, 2003
    416
    I understand Digi Cable. But, would ER come through in Hi Def over analog?
  4. Steven.W.T
    Steven.W.T Stunt Coordinator
    May 20, 2004
    90
    If you have a OTA ATSC tuner then you should be able to just plug in an antenna and watch it. You might need a better antenna though, DTV signals are picky. If you live in a big area the big 4 channels probabaly broadcast regular and digital signals. You can get it for free.
    Most cable companies dont send you digital signals. They will make you pay for it. Why dont you call and ask your cable provider?
  5. Chris Huber
    Jan 2, 2003
    416
    Yeah, I might call them... They don't send a whole station 24x7 on a digi/analog signal. They only do big budget shows, like ER, cause they had the equipment to film it that way, right?
    I might call them. What question should I ask them? The first 3 or so people I talk to probably won't know what I am talking about and try to sell me Digi cable. [​IMG]
  6. Geraldine/F/M
    Jun 2, 2004
    31
    If you don't watch movies, and want HD in broadcast, buy an ATSC set top box and a GOOD HD antenna. You'll be able to receive programs broadcast in HD. ER is one. Also, I think are about a dozen others. You can still keep your cable and use the set top box.
    To get HD on cable, you'll need a high definition cable box and will need to subscrbe to the service. [​IMG]
    Geri
  7. Chris Huber
    Jan 2, 2003
    416
    I already have ATSC built in. What is an HD antenna. I am not familiar with that.
  8. RandyMathis
    RandyMathis Stunt Coordinator
    Jan 19, 2003
    94
    I have a 30+ year old rooftop antenna that gets HD in very nicely.
    You just need an antenna that is pointed in the right direction and that is high enough to get the signal.
  9. Chris Huber
    Jan 2, 2003
    416
    I already have regular cable, so HD ER can come through that, correct?
  10. mark alan
    mark alan Supporting Actor
    Nov 19, 2002
    620
    no that is not correct. you must have digital cable and settop box capable of converting the high def signal.
  11. JimMAC
    JimMAC Agent
    Mar 29, 2004
    40
    Chris, read all about it Here
    This should help you get started with HD on over the air antennas.
    Mac
  12. Matthew Todd
    Matthew Todd Second Unit
    Jan 3, 2000
    338
    Chris, you have regular cable, but do you actually have an antenna in your attic or on your roof?
    If you have an antenna, just make sure the antenna is attached to the TV, and since you already have the ATSC tuner built in, that should do it.
    Matt
