Digital Path Recievers (1 Viewer)
A
AndrewWhi
I am looking for a new reciever, and was wanting to know the difference between the Harman Kardan AVR and DPR recievers.
David Judah
The AVR's are traditional designs employing ADC's, DAC's, and analog amps. The new DPR's use a digital amp module from D2Audio. There may be ADC's in the signal path depending on the input, but the DAC is the power amp itself.
Ideally, you want to input a digital signal, which will pass through the DSP and then will be converted to PWM for amplification. The theory is that as the signal is in a digital state, it is less prone to corruption that can happen in the analog domain.
DJ
David Judah
Here is some additional info on the DPR's. I'm interested in them as well. I have a cheap little Panasonic with digital amps(although they use a different digital amp chipset)that sounds remarkably good, so I'm sold on the digital amp idea, however, I like the fact that the HK's are at a higher price point, appearing to make less compromises in the design.
If you get one, let us know how you like it.
DJ
A
AndrewWhi
Sure thing. That info helps a lot in understanding some of the differences between conventional recievers and the digital ones.
Are digital recievers going to be the norm in the future?
Tabish
Grip
__________________________________________________ __________
More and more companies going digital route, So I think that would be the future, we will find more and better quality products.
fadilale
