digital out on my dvd player
Discussion in 'Playback Devices' started by tommy_E, Apr 12, 2005.
  1. tommy_E
    tommy_E Agent
    Mar 23, 2005
    49
    how u doin can anyone help?
    on my dvd player(sony dvp-650v} the digital out seems lose..the cable comes out easily...doesnt "snap in"...it "snaps" into place when i pop it in my receiver,,,but when i put it in the dvd player..its very loose? any suggestions? thanks alot.
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,111
    36
    6,610
    Katy, TX
    Wayne
    I assume this is the optical cable? Replace it – it’s probably the problem.
    Wayne A. Pflughaupt
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    If it is reversed that would determine if it is the optical cable or the receptacle on the back of the dvd player. If it is the dvd player and it is still under warranty then it could possible be repaired without ### involved, if not under warranty then we need a way to secure Tommy's cable.
    Question, do you get any audio dropouts at all?
  4. tommy_E
    tommy_E Agent
    Mar 23, 2005
    49
    what do u exactly mean by audio dropouts? sry dumb ques?...i tried another digital cable {same one} from another component..its still lose? so its not the cable.
    my dvd player isnt under warranty i got it a few years ago...its the dvd..cd and sacd player(dvp-nc650v sony} its known for the display to go out once and a while so i guess its got its own known problems..
